coolmom42
Feb 25, 2016Explorer II
Old-Biscuit wrote:
Propane tanks don't need re-certification as they are ASME jurisdiction/standards!!
Propane cylinders under DOT have to be re-certification done 12 yrs after mfg. date stamped on collar and then every 5, 7 or 12 yrs depending on type of re-certification (External Visual, Proof-Pressure or Volumetric Expansion)
Propane BULK dealers can do re-certifications----certified by DOT for as a 'requalifier'
Some propane fill stations can do it IF they have been certified by DOT as a 'Visual' inspector
Propane Cylinder Requalification Guide
CYLINDERS are the portable things usually no more than 30 lb capacity, that you take off to get filled. These have to be re-certified according to the schedule OldBiscuit gave.
TANKS are larger and permanently attached, generally on motorhomes.
Using the terms incorrectly is a source of great confusion.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
