Mortex's avatar
Mortex
Propane Certification in Ontario?
First off I've been reading the forums since fall and have learned a ton. I purchased a 1998 Class C MH late last fall and only had it out once before i needed to store it for winter. I've used it a few times this spring which has brought up my need for refilling the LPG tank for the first time.
I went to a propane place to get it filled and was informed I needed a sticker or documentation stating that my tank was safe to fill due to it's age. I didn't get anything from the previous owner so I'm assuming I need to do this. I called the only local place that says they do it and was told I need an appliance inspection sticker before I can get my tank checked due to new regulations that just started.
Has anyone else ever had to deal with this? Does all this need to be done? From a safety standpoint I get it should be done but the place for the appliance inspection alone says it will be at least 2 weeks before I can get it in even though the inspection should only take about an hour.
I had planned to use it as many weekends as i could before the summer as I'm planning a month long vacation in it. Trying to learn everything I can about it before I take it. Maybe I'm just ranting because now i have very little LPG and can't refill for weeks.
Just wondered if anyone else has run into this issue?
