- ktmrfsExplorer III
dougrainer wrote:
hotpepperkid wrote:
Go to Harbor Freight and get one of those metal stamping kits and restamp it
In Texas they do NOT stamp them but put on a weatherproof sticker. Doug
that's the case in virtually every state since it is a federal regulation. they put on a new sticker. new stamp may work for someone who is not educated. hotpepperkid wrote:
In Texas they do NOT stamp them but put on a weatherproof sticker. Doug- vic46Explorer
REALLY!!!!!!!!!!!!!!!!!!! - KountryguyExplorerInteresting concept!
- hotpepperkidExplorerGo to Harbor Freight and get one of those metal stamping kits and restamp it
- TucsonJimExplorer IITank? Cylinder? I always thought they were whatchamacallits.
- red31ExplorerNFPA 58 definitions
Container.
Any vessel, including cylinders, tanks, portable
tanks, and cargo tanks, used for the transporting or storing of
LP-Gases
ASME Container (or Tank).
A container constructed in
accordance with the ASME Code.
(See Appendix D.)
Cylinder.
A container constructed in accordance with U.S.
Department of Transportation specifications (Title 49,
Code of Federal Regulations) - KountryguyExplorerPoint well taken. I have a 30# cylinder that needs to be re-certified.
- coolmom42Explorer II
Old-Biscuit wrote:
Propane tanks don't need re-certification as they are ASME jurisdiction/standards!!
Propane cylinders under DOT have to be re-certification done 12 yrs after mfg. date stamped on collar and then every 5, 7 or 12 yrs depending on type of re-certification (External Visual, Proof-Pressure or Volumetric Expansion)
Propane BULK dealers can do re-certifications----certified by DOT for as a 'requalifier'
Some propane fill stations can do it IF they have been certified by DOT as a 'Visual' inspector
Propane Cylinder Requalification Guide
CYLINDERS are the portable things usually no more than 30 lb capacity, that you take off to get filled. These have to be re-certified according to the schedule OldBiscuit gave.
TANKS are larger and permanently attached, generally on motorhomes.
Using the terms incorrectly is a source of great confusion. - wa8yxmExplorer IIIPortable tanks need recert.. I took a 25 or 30 (not sure which) they not only re-certified, but replaced the valve and re-filled, Total bill was like 60 bucks as I recall (may have been less) Including the new valve assembly and the propane. .
Your local propane supplier may do it (did in this case) but look for the kind of facility that runs bulk delivery. not a "Swap a bottle" place.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
