cmt246
Jul 11, 2016Explorer
No tubing wrenches needed. 1/2 - 5/8 open end. If it was like mine you will have tee's off the pump on the pump side of the tee there is a jam nut loosen the nut first then the tee will remove easily, you will need to reuse the tee so be careful not to damage the o ring.
One other thing you might need to be prepared for is adding a ground wire. On my factory install it grounded from the battery to the pump body, which was metal and made a good ground, not the case for the ground lug on the new pump so a drill and a little wiring may be needed.
All in all simple job once the tranny fluid is all cleaned up.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 20, 2025
