Thanks all. I did try the WFCO and it supplied 14.4v for a few minutes before going to 13.6v. Not a good option to quick charge with a generator.
Regarding the PD 9200 series (non lithium)...I can use the charge wizard to bulk at 14.4v and hold it there for 4 hours. If before that 4 hour period is up and the battery is ready to absorption, will the PD move off the bulk phase?
For most part, will be zapping battery with generator for a few hours at most. So will still be in the bulk phase. But If I want to fully charge, will the PD9200 do that if I use the charge wizard set to bulk at 14.4 and absorption at 13.6, or will I have issue as the WFCO and bulk cuts out after a few minutes?
