Yes the system has the proper amount of R134A - low pressure switch is ok (closed). Have yet to test the high pressure switch.
Going back to the schematic - this is a Denso wiring diagram I got by getting the part number off the dash control and searching the web. The schematic is for the interior heat/cooling unit inside the cockpit. According to Tiffin AC service tech the Denso unit sends a 12V signal (the output of the "Magnetic Clutch Relay" pin 3 at top of page) to the Workhorse chassis. I believe the part shown to the right of the label "Light Switch" is a generic destination since Denso doesn't know what vehicle their unit is installed in.
Under the hood the diagram in the cover of the fuse center shows a 10A fuse labeled "Comp" and a relay labeled "Comp". This fuse and relay feed the compressor clutch.
When I depress the AC ON button on the control panel it applies 12V to one side of the coil and to the contacts. All I need is a ground to the other side of the coil - this must come from Workhorse installed sensors like the Hi and Low pressures switch's.
As a retired EE I have 48 years electrical experience and I am EPA certified in HVAC including mobile - but without a schematic for the Workhorse side I am flying blind.
Since there is protection for pressure and temperature in the Denso unit I think I can safely permanently ground the relay coil under the hood and forget figuring out what it should be..............
