Mike_P_ExplorerJan 25, 2021DripI have a small drip coming from the 1 1/2" black pvc pipe from the gray water tank. Not sure where its coming from yet, could be the pipe or a joint? If I can find where the leak is coming from is t...Show More
dpglifestyleExplorerJan 25, 2021I used JB Water weld to fix a cracked fitting on black tank. this stuff is made to fix water leaks and will even work under water
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
Related ContentOxygenics Fury RV Handheld Shower head --COLD dripCITY WATER CONNECTION DRIP?Rusty Water DripWater DripDrip Pot Diesel Stove
