edpelo
Mar 30, 2014Explorer
mena661 wrote:
One or both batteries are bad. Unless you have a bad fuse somewhere, you pretty much eliminated the charging systems. I would put one battery at a time on the chargers (use the inverter/charger it's quicker). Fully charge it, disconnect for 24 hrs then note the voltage. Repeat for the other battery. Post the results
If bad it will lose voltage even while disconnected correct?
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
