edpelo
Apr 01, 2014Explorer
MEXICOWANDERER wrote:
Square Wave tester - better than a cheese grater. Hydrometer confirmed your batteries are discharged.
Your batteries are SULFATED. Read up on the process of EQUALIZATION. You cannot "standard charge" a sulfated battery. The battery must be equalized.
This is a common problem and no (affordable) battery charging/maintenance system on the face of the earth can prevent a deeply cycled battery from sulfating, sooner or later.
Two questions:
What would you consider a deeply cycled battery? Mine are about 5 months old and I do not discharge them past 50%. Regardless, in my readings it appears doing this once or twice a year is a good idea or when batteries start displaying behavior similar to mine.
Can I take them to a battery shop and have them equalized on one of the high end chargers? I do not have equalization on my chargers.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
