Gjac
Aug 11, 2018Explorer III
agesilaus wrote:This is true and really depends on how bad the water damage is. Epoxy resin by itself has little strength. If the plywood is intact a cheaper solution to these expensive low viscosity epoxies is to buy basic resin either epoxy or polyester and thin with a solvent like acetone. The viscosity will be like water and absorb into the plywood easier. Once absorbed the solvent will flash off very quickly. 40 years ago or so we used to buy a product to seal leaking molds called "Waterglass", using thinned resin with acetone was much cheaper and did the same thing. Also if the area is still moist or wet and you soak the area with acetone it will absorb that moisture and evaporate very quickly removing that moisture with it. Good luck if you decide to do this repair.valhalla360 wrote:
The problem with any of the penetrating epoxy solutions is by the time you open it up and get access to apply the epoxy...it's less effort to just cut out the bad plywood and put new in.
That's generally true, plus a sheet of plywood is a lot cheaper than those epoxys are.
