acemyers
Jan 05, 2014Explorer
charlysmom&dad wrote:
In our mh, some outlets run through the invertor. Even though the inverter is not on, if the inverter circuit breaker trips, we lose power to some outlets.
Just one more thing to try before you call a tech. The inverter circuit breaker.
I have no clue as to where to find the inverter circuit breaker. I was only able to find one inside, which was the main one. I checked outside as well and nothing.
I've unplugged everything that was in any of the outlets and then reset them and nothing. I plugged in a lamp in the GFI outlet and turned the breaker off then back on and the lamp came on as if it was a very cheap night light, still some power, but not full. Then I turned the switch off on the lamp and back on and it wouldn't come on at all.
Where are the inverter or converters normally located? I thoroughly searched everything and really only found one breaker.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
