timc1207
Mar 05, 2014Explorer
timc1207 wrote:donn0128 wrote:
When did you turn the gas on before the trip? Did you purge the air out of the gas lines before you tried starting the furnace?
Yes purged and was working for the last 4 nights with no issues after the initial hiccup. I'm thinking the flame sensor.
Been doing a lot of web surfing on this and it seems to be a common problem. I had this furnace worked on last year and it cost as much as a new replacement. I think this time I will just put in a new one and be done with it.
I pulled the unit out and checked all the wiring; looses connections seems to be the most common cause. Re-installed the unit and now it is working again but I have zero trust in it.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
