I turned off the generator while both AC were running, now the Generator runs crappy, like it has no guts, even if I remove the plug that feeds from the Generator to the RV. PS The AC's still work fin...
You are getting a lot of good advise here but, have you looked to see if the choke is sticking? On my Generac NP66G the choke stuck closed and caused the genny to run ruff and not output the correct voltage. I had to pull the air cleaner completely off to see the choke and the slight rust problem that caused it. This might not be your problem but I did not see on your thread were you checked for this and it would take just a few minutes to do.
Good Luck
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
