Jim_McGarvie
Aug 06, 2019Explorer
MEXICOWANDERER wrote:
Photos label tags and more photos...
If you decide to replace the transfer relay inside. Remove the inverter from the vehicle. Do the work on a bench with a comfortable seat. Super bright illumination and get a set of reading glasses that focus 4" in front of your nose.
I cannot remember which brand of inverter had Torx security screws T10 on the inverter shell.
The ID printed on the relay is tiny. This is where reading glasses are mandatory. Take several images of the relay in place before proceeding. It does not allow for oops.
It's not a difficult operation if you remain patient and organized.
I called Xantrex technical support and the pleasant gentlemen explained where to find the fuse associated with the circuit controlling the bypass relay. I was able to access it without removing the inverter from the coach, and sure 'nuff the fuse was blown. I replaced it and everything works normally. All this for a little 1/4-amp, buck-and-a-quarter fuse.
Thanks to all who contributed advice.
Jim
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
