ibyers
Mar 11, 2021Explorer
3 tons wrote:ibyers wrote:
Hey all, I know this is a older thread, but thought I would ask here first before starting a new thread.
I picked up this transfer switch and looking at the wiring diagram(s) it suggests to add a fuse to the Charger/converter circuit, However it really does not give more information than this.
Looking at fuse options, and other threads, a 15 amp fuse for this leg of the circuit seems to be the norm. That being said, would this fuse be ok? (I like the idea of drilling a hole in the case and mounting for easy access to the fuse).
Acouto Panel Mount Fuse Holder 5PCS Electrical Panel Mounted Screw Cap Fuse Tube Holder for 6x30mm Glass Fuses AC 125V 15A / 250V 10A
Amazon Canada Link
Well, per the diagram the fuse they are suggesting is between the charger and the battery (unrelated to the ATS...), so in this case the fuse size would be dependent on the rated output of the charger, plus say 10%...But your charger may already have such a fuse (a blade type fuse) integral on it’s body...
3 tons
Hi 3 Tons, the fuse I am referring to is inside the one transfer box. Top left corner of the box.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
