vern_kelly
Jul 14, 2023Explorer
Jimh406: You might test it with an ohm meter after you remove it from the wall and disconnect the wires. May be able to work some contact cleaner into the switch itself. The prime is not needed on the propane generator like the gas ones. Just start and stop. Might have to do multiple starts if propane has been turned off a while. I wait ~30 seconds between start attempts.I take it always works fine from the switch on the generator itself just not so handy! I have the same setup on my Lance TC.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
