wittmeba
Dec 31, 2013Explorer
Francesca Knowles wrote:
There's nothing in the O.P.'s threadstarter that indicates a GFI's involved...
It was stated "they tripped the outlet". As doughere stated, outlets don't trip due to overload - only short circuits.
doughere provided the best information.
If it pops/trips instantly it is more likely a short rather than an overload. Overloads take a bit of time depending on the magnitude of the overload to heat the thermal trip elements. GFI is instantaneous.
To the OP:
You are obviously using a conventional 15/20 amp extension cord for the last connection to the GFI. Are you using a 3 wire and are all the prongs are present and working?
Yes it is possible when the "automatic" cord was replaced it might have been installed/wired incorrectly and causing the trip of the GFI.
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 05, 2025
