BBdawg
May 30, 2014Explorer
I have fan set to "auto" and like you state, if fan is on "on" it just runs continuously.
To get it working the way it is right now, I had to set the HG/HE switch to "HE". When set on "HG" (as it should be), the A/C fan only runs when fan mode is selected to "on". The a/c fan then also runs when the heat come on. NO fan period when set to auto. but the a/c compressor does run, just no fan in auto mode.
A side note: This is the 2nd Honeywell stat I tried. The first was a little more expensive but I had the same problem with it, so I took it back. I got this one, at Lowes, as it was the exact model used by another camper in one of his mods, back several years ago. Same model but obviously not the same circuitry.
I wanted to move back to a Hunter as the one I finally got working in our old TT was working just fine BUT Home Depot, Lowes, Ace Hardware nor Wallmart carry the Hunters any more.
Also, the whole system still works as designed when I reinstall the analog stat.
I have tried several of the many wiring set ups offered by others, even one that blew the heater 15 amp dc fuse.
I would sure like to get this working and post on several forums a 2014 answer to the Honeywell thermostats, so others have an easier time making the upgrade.
Your help is appreciated!!
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 24, 2025
