HappyCamper44
Jun 01, 2015Explorer
Replacing coleman thermostat
To catch everyone up to speed, I have a 97 Gulfstream Conquest 26FBD. Started having an issue with the A/C compressor not coming on intermittently. It still has the original manual Coleman thermostat. I downloaded a troubleshooting guide to figure out what the issue is. After following the flow chart checking voltages with my digital volt meter, it comes up that the thermostat needs to be replaced. I have now found out that these thermostats are made to be able to control the fan at 2 different speeds, unlike a home thermostat that only controls one speed. After finding this out, I did some research, and found out there is a mod that will let me install a standard home thermostat "IF" I can find a 12vDC 3 position (hi/off/low) switch to control the fan speed to mount right beside the new thermostat. Just wondering if anyone here has done this, and if so, where is a good place to find the low volt switch? Pictures would be awesome too if someone has any.
