I have 1 drum brake that stops hotter than the other 3. I replaced all seals because of grease leakage. Hot brake was greaseier. I cleaned better than others. Do I need to clean other 3 better? Do I n...
I recently had the same problem and fixed it myself after Lippert sent me new everything at their cost. Search my thread under General RVing issues, TT brake sticking. If you read my last post you will see what I found. It's very likely you have the same problem with the arm that holds the magnet having too much "play" in it. When I was dealing with my problem I also found a YouTube video on this problem also. Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
