mondmn70
Dec 18, 2014Explorer
dougrainer wrote:
1. Temp rise on your model will not cause any indication or beeping.
2. IF there is a failure, you will get a flashing LED stating what has failed
3. Should the door be kept open for too long
(more than 2 minutes), the blue external
LED starts flashing until the door is closed.
Only with AES models an acoustic signal is
initiated (pulsing whistle tone).
?? Should the electronic control detect any failure,
an acoustic signal will sound (pulsing
whistle tone) for 30 seconds (only with AES
models). It is repeated every hour, if the fai
lure is not resolved. At the same time the
display starts flashing (for trouble-shooting,
please refer to section 4.13).
4. For a problem like this you usually disconnect the Temp Thermister which will cause the refer to run full time. Then see if it stops cooling in your parameters problem. IF so, then replace the Thermister.
5. Does your model have the optional rear cooling fan? Not ALL of this model will have the rear cooling fan. If you have the fan, then your fan Tstat may be defective. Doug
Doug, I do not see any flashing LED's when the fridge (AES model) is not cooling. The first couple of times that this happened, I did hear a beeping sound that was the same as the beeping sound when the door is not closed completely but no beeping the last few times it happened.
4. Disconnecting the temp thermistor is an excellent suggestion and one I can easily try the next time it happens.
5. I do have the rear cooling fan but it seems to work fine and runs when the fridge is not cooling properly.
Thanks for the suggestion.
Mike
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
