Funny thing, I took my 5th owl in for ac work. Now all the running lights are on. I'm plugged into shore power at the park. My truck is not connected. What gives? How do I turn them off?
As mentioned above, sounds like the pig tail connector on the 5th wheel is shorting (corrosion, etc). I had a problem with my Chevy Colorado where my running lights would not turn off. Tore the 7 pin connector at the rear of the truck apart. Corroded...BAD! Replaced it and the light issue went away.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
