steelshooter
Mar 09, 2020Explorer
Doug, There is an LED Stop light bar installed. It may not be factory but the back cap has an indentation for the light bar to recess into the cap. The response to the diode splitter sounds like what is actually happening. The noise seems to be located half way between the stop light bar and the right tail light. I believe it is in the cavity between the cap and the frame, thus I can not see from inside the camper or from under the trailer when I drop the belly cover. You are also correct about checking the system before we travel. Also if pyoung47 were to hear this in a campground he would hear it every time I put it into hit the brake to park the camper. It is actually that obnoxious.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
