MHancock
Sep 25, 2019Explorer
ndrorder wrote:
If it is the main 12 Vdc breaker that is tripping, do you have an inverter that may be pulling too much current in the transfer off the generator? Loose contacts in the generator/inverter transfer switch causing inverter to pull more load.
If it is the main 120 Vac breaker, the DC battery kill switch will have nothing to do with it. Does your coach have a shore line to generator transfer switch that may have loose contacts or be drawing too much current in the transfer? Invertor delivering too much current?
the main is a 40a breaker. i have replaced the original inverter with one about double the original one.
and i will check out the second part of your response.
thank you
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
