calgator734
Oct 30, 2014Explorer
jrnymn7 wrote:Snowman9000 wrote:calgator734 wrote:
Am I missing something? You're not seeing too much of a drop...just 2%.
At how many amps?
2% at 10 amps becomes 8% at 40 amps, for example.
Actually, it's more like 4%:
0.54v / 13.6v = 0.0397
The voltage load curve for these wfco converters indicates max current at ~13vdc. The only way to get the min volt drop at high amp is to run 2 gauge wire (largest wire wfco will accept). I think op is on to something when looking at other things in between the battery and converter with high resistance)
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
