S/w - software, f/w - firmware, h/w - hardware
I have had load support on and Magnum has kicked out genny and only run from batteries as genny voltage dropped too much. Then it won’t let genny back in because same happens each cycle.
I have not seriously throttled input current though (ie - 50% of genny capability or less), this *might* prevent genny voltage from dipping too much? I’ll give that a try next time in this situation. If that doesn’t solve it then I’m probably limited to either wiring in an inverter bypass, or changing to a more robust generator (Honda’s seem to support voltage much better than my Westinghouse, and Honda is coming out with fuel injected models - $$)
