Discovery8
Aug 18, 2018Explorer
Artum Snowbird wrote:
Because you have lost a considerable number of outlets and devices, you have likely lost one side of your 50 Amp service. If you can reach a different 50 amp receptacle from your unit, even with a 50 amp extension, try that.
Your power comes into the panel on two sides of your breaker panel. If all your losses are on one side of a double sided board, you have lost one side. If all your losses are every second receptacle in the panel board, you have lost one side.
It's either that way on the plug in outside, or something in your plug or in your panel has become disconnected.
Further to your problems, your inverter will be fed from only one side of your 50 amp panel, so it is very likely that because of your dimming lights, either the inverter has not got enough power from the failing circuit, or if as others have said, it's a flow through inverter, then the feed through the inverter has a loose wire in it possibly.
Do a circuit by circuit analysis of your panel to determine if all the bad things are on one side of your 50 amp service first, then get competent help with that knowledge in hand. Do not replace anything until you figure out why it is not working properly.
Thanks for the information. This is helpful.
Having RV issues? Connect with others who have been in your shoes.24,269 PostsLatest Activity: Jun 15, 2025
