Re: Mixing solar panel sizes
Yes you can parallel eg, a "12v" 160w panel with a 12v 100w panel for an array of 260w. BUT you cannot mix voltages such as add a 12v 100w panel to a "24v" 255w panel.
Better not to mix mono and poly either--they act a little differently in low light. Can be done though.
You can have a 24v set of panels with its own MPPT controller and another set of 12v panels with its own PWM controller, set both controllers to the same high set point voltage 14.8v eg, put both controllers on the same battery bank, and they will add their amps.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
