Re: my propane generator won't start
It could be just me but I’m not sure what you are referring to when you say “intake filter”. Do you mean the filter on the gas line or the air filter.
  • way2roll's avatar
    way2roll
    Trailblazer
    Why would there be an in line gas filter on an LP generator?
    • bid_time's avatar
      bid_time
      Nomad III
      My bad, all the propane gas equipment I worked around (including generators) had filters on the fuel line to remove contaminants. I didn’t realize the low wattage generators apparently are lacking such protection.
      If it’s the air cleaner causing the issue; it must be working in an unusually dirty environment or needs a better filtering system.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
