Good Morning I hope I am not posting this question twice it went away into computerland but I do not know where. I have a 2002 Holiday Rambler Endeavor, diesel pusher. It has been parked awhile and ...
Yes the Xantrex is inverter/charger. The inverter part works fine. I turned off the shore power and the inverter switched the AC on. I did not know the inverter would also be the converter. I guess my problem must be in the wiring connecting the inverter to the DC panel. I pulled the DC fuse panel and see a large red wire on the input lug so will have to find its origin. Thanks again. I will try to find a way to follow the input wire to the fuse box. Pam
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
