mtnman1989
Jul 18, 2023Explorer
OK, here is an update.
When we got home from dry camping yesterday morning, we plugged the camper into 110 outlet and turn the refer on. This morning everything is working perfect, the freezer is minus 10 degrees and the cooling bottom is 30 degrees.
What do you want me to check next?
Do you think it could be the tstat for LP?
I assume that I have an LP problem only? I was thinking about turning off the LP tanks and disconnecting my LP line at both ends and blowing it out. If that don't fix it, I may need to replace my regulator?
We looked for a cooling fan and there is no cooling fan nor has there every been one. Which is a good thing since 90% of our camping is dry camping without electric.
Just so you know, while dry camping last week I disconnected my 12 volt batteries and the LP to the refer stayed on.
Thanks!
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
