144Grayling
Nov 10, 2023Explorer II
Thanks for all the information. The battery is a 12 volt lead acid RV deep cycle battery from Les Schwab. No reason to think it’s not what it says it is. As far as I know the only 12v functions in the trailer are lights, bathroom exhaust fan, radio and propane alarm. All those are fine on what’s coming out of the converter now: 12.9v No slide out, no hitch jack. Checking the panel it also has a few other 12v circuits that we don’t use ( dont need the water pump since we’re hooked up permanently, and the furnace, since we use electric heat instead of propane.) And it says the hood fan is 12v which I didn’t know. So everything we need is working fine off the converter and shore power. I don’t know why the converter was overcharging the battery to the point of boiling, but if it can go without a battery I really don’t need to care about it. I suspect that I killed the battery by leaving it outside uncharged over a couple of winters and that’s my bad. But, again, if I don’t need a battery in the system I’m ok. Still getting mixed opinions on that.
- MNtundraRetNov 22, 2023Navigator
Unless the trailer is sitting on a seasonal site, you need a functioning battery to tow the trailer. A battery is needed for lights, turn signals, brake lights, and brakes.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
