ktmrfs
Nov 10, 2023Explorer II
144Grayling wrote:
Thanks for all the information. The battery is a 12 volt lead acid RV deep cycle battery from Les Schwab. No reason to think it’s not what it says it is. As far as I know the only 12v functions in the trailer are lights, bathroom exhaust fan, radio and propane alarm. All those are fine on what’s coming out of the converter now: 12.9v No slide out, no hitch jack. Checking the panel it also has a few other 12v circuits that we don’t use ( dont need the water pump since we’re hooked up permanently, and the furnace, since we use electric heat instead of propane.) And it says the hood fan is 12v which I didn’t know. So everything we need is working fine off the converter and shore power. I don’t know why the converter was overcharging the battery to the point of boiling, but if it can go without a battery I really don’t need to care about it. I suspect that I killed the battery by leaving it outside uncharged over a couple of winters and that’s my bad. But, again, if I don’t need a battery in the system I’m ok. Still getting mixed opinions on that.
12V is needed for a propane/electric fridge (even on shore power) water heater (even on electric) usually for propane and sometimes CO detector
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
