bounder39zman
Apr 11, 2023Explorer II
When you say the generator will not "start"...do you mean it will not turn over (crank) with starter, or it cranks but will not run?
The problem with LP fueled systems is usually fuel related, and many times is simply a plugged up LP regulator atmosphere vent hose. Insects, namely wasps or dirt-dobbers love the smell of LP and crawl up hose, build nests, and stop up the hose. then the regulator diaphragm cannot move freely to allow fuel to engine. Do not blow high pressure air into regulator, it will rupture diaphragm. remove hose from regulator, then blow it out. Of course, do basics first. Ensure spark is getting to spark plug, and regulator at fuel tank is supplying fuel to generator.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
