alaska_dennis
Nov 13, 2019Explorer
timjet wrote:
The original poster here; I went to the coach yesterday and started the generator, it started up normally. It ran normally and sounded normal for about 15 minutes until I shut it down.
I don't think I have an oil pressure issue, I think it is an electrical issue. I'm going to investigate the electrical control on the unit paying close attention to the connectors.
When is the last time the fuel filter was changed? Not much electrical on diesel. Check voltage on fuel shutoff on injection pump. The next time it shutoffs on you and voltage on electric fuel pump if you have that.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
