MopaRV
Apr 30, 2022Explorer
bounder39zman wrote:
The problem as described by initial poster is caused by starter drive. Onan tech for 35 years+. Have fixed this issue literally dozens of times. have worked on hundreds of Microlite/Microquite gensets, and seen engines lock up due to broken con. rods, crankshafts, balance shafts, camshafts, dropped valves, seized rotor bearings, etc. However, since it can be freed up by jerking on flywheel/blower wheel, and then seems to run ok, would bet the farm on being a starter drive problem.
Thanks. I was leaning toward the starter being the problem also.
I figure I'd keep going with it for a few more weeks until I have the opportunity to drop the generator for repair. And what might be the issue? Starter gear not retracting? Starter gear broken tooth? Can anything REALLY BAD happen by me continuing to use it with questionable starter drive issues?
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
