cdcorpeExplorerOct 14, 2015parasitic drainMy rv has a 12 volt valve for the propane tank with to much parasitic drain, is there a way to leave the valve in the open position without the battery drain? ( it has a manual shut off) I tried a lar...Show More
cdcorpeExplorerOct 14, 2015The device is on the propane tank so it serves everything in the rv, but in order to use the propane you have to turn on the 12 volt valve, yes I have measured the drain. I would like to keep the valve open without using any 12 volts & manually turn it off when I am home. This is what the valve look like http://www.ebay.com/itm/SOLENOID-VALVE-PROPANE-MOTOR-FUEL-TANK-12-VOLT-LOCK-OFF-VALVE-12V-LPG-LOCKOFF-/141730711967
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
Related ContentParasite control issues helpGrey water tank won't drain completelyParasitic loads - GM trucks & SUV'sHelp - jacks are draining my batteriesBlack tank not draining!
