Sjm9911
Aug 07, 2022Explorer
Gdetrailer wrote:Sjm9911 wrote:dougrainer wrote:Sjm9911 wrote:
Doug, and what advice do you have have that is maybe helpful to the situation? I did say some like it and some dont? And i believe I said to do it as a last resort? At least now we know where you stand. Almost like we needed the helpful advice. Oh, no , we didnt. Lol.
I am just stating a FACT. After 43 years as a RV tech, I think I would know what works and what does NOT work. If a person wants to take the time to remove the refer and then spend a couple of days rotating the refer and then reinstalling. Then do it. A LOT of work for something that will not work. Years ago People with a blocked refer would burp when selling and the refer "appears" to work when they sell it, but a few days later it is blocked again and the new owner is stuck. Newbies have no idea how much RV refers cost and cost to replace a cooling unit. Blocked refers, the freezer will work, THAT is what gets buyers to think the refer is OK. Doug
Ok so it works just dosen't last? Trying to read in between the lines. I dont know how it would appear to work. It works or it dosen't. I get it may not last, depends whats in the tubes blocking it. I do know with the smaller ones, people have had sucess that lasted years.
If it doesn't last or last long, did it really "make it work"?
So, one must ask themselves the question, how many times per trip am I willing to remove a 120+ lb fridge, turn it upside down, turn it back over then reinstall it and cross all your fingers and toes and hope it works again for the rest of the trip????
Really, if it is dead (IE not working properly), either do a proper repair (like a new cooling unit) or replace entire fridge.
Burping is a temporary bandaid which may last 1 hr or it may last yrs, one really does not know for sure since there is no magic window to peer in to see where the blockages are. Once you start having internal crystallization (which is what creates the blockages) the game is over, one crystal begats another and another each cycle..
Take a fridge out ONCE and I can assure you that you really will not wish to do that again.. Bigger fridges takes two people, might get away with one person on a 3 cuft ones but anything of 10 cu ft or larger you are in the 120 lb+ weight and they are insanely top heavy.
See thats the info and knowlage you should share. Given you experiance and all that. I get people get board helping others, but tbh, you have good things to say, then say them. Not the boilerplate it will not work. Dont be that guy doug, your much better then that.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
