alaska_guy1
May 16, 2016Explorer
fridge doesn't work on propane.
So I have a 2014 lance 865 that I bought from a dealer up here and their service center iis bad... They would fix my issue under warranty but I don't believe they are a very competent service center and don't want them touching my rig. Long story short they said they checked everything out prior to me picking the unit up and when I took it out the shower had a leak, fridge didn't work on propane and they gave me the wrong piece used to make up my dinette.
Sorry for the back story... on to the issue at hand. So the fridge requires me to push on a button for a few seconds and then push in another button for my igniter. I assume the first button is the pilot jet for the propane. The second button is the electric igniter. I have verified I get spark, the pilot will light but I get a weak main burner flame. Eventually after 10 seconds or so the main flame looks like it has a leak, or somehow it is catching the pipe on fire behind the orifice on the main burner. I can blow it out as its a yellow flame but the leak will catch on fire again etc. 1. This doesn't seem safe. 2. My fridge never gets cold enough. Fridge works fine on AC and DC. So the fridge unit is fine...
This looks like the main jet my burner takes.
http://www.walmart.com/ip/44027531?wmlspartner=wlpa&adid=22222222228032018330&wl0=&wl1=g&wl2=m&wl3=61133303096&wl4=&wl5=pla&wl6=108545898056&veh=sem
I have tried vacuuming out the fridge area along with compressed air. Neither seemed to remedy the issue.
Can I just swap out my current soutty orifice with a new one to resolve my issue or should I take my camper to a pro?
The warning about possible explosion or death seems worry some.
Thanks.
Thanks.
