mcewena
Aug 29, 2023Explorer
Gary45 wrote:mcewena wrote:dougrainer wrote:
USA ASME tanks are not required for certification. Are you POSITIVE, that Canada requires ASME certification and not just DOT portable tanks which DO require recertification? Doug
I’m positive that some fill stations won’t fill my tank. That’s what matters in the long run.
Canadian regulations are hard to pin down but I talked to a local propane recertifier and he said he probably wouldn’t pass mine due to the rust so I know I’m on borrowed time with it.
Clean it up and paint it, they do not want to see rust. ASME tanks do not need to be certified in Canada. My motorhome 1986, tank is clean and painted.
Yeah that’s probably he cheapest and easiest option.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
