Cadillac_Jack
Oct 22, 2014Explorer
atreis wrote:
Wiring them in series lowers the line losses between the panels and the controller (it's amperage - the flow of electrons - that's resisted - and the higher voltage - how hard those electrons are being pushed - helps too). The MPPT controller will take care of outputting the correct voltage to the batteries.
When wiring different panels (or sets of panels) in parallel, the VoC should match as closely as possible. (If producing at all, most panels will produce they're rated voltage, even if they're mostly shaded and producing very low amperage.) If it doesn't, the lower of the two voltages is what will be used, with any difference wasted.
When wiring different panels (or sets of panels) in series, the VoC does't matter much (with an MPPT controller) but the Imp should match as closely as possible. If they don't match the higher-current panel will end up being limited to the same amperage as the lower-current panel with the difference wasted. (If the panels don't have bypass diodes, the same thing will happen if one of the panels is shaded. Some panels, Kyocera for instance, have bypass diodes between groups of cells as well. Some of the super-cheap panels don't have bypass diodes at all.)
There are many references online, some better than others, for the fun of wiring in series vs. parallel, and series-parallel. These are but a few:
Solar Facts
MPPT Solar
Solar Panels Venue
Exactly right. Not sure what the other gentleman is talking about. My batteries are 12 Volt. The camper is set up for 12 volt. Two 6 volt batteries in series are 12 volt. Meaningless for this discussion.
Higher volts push more amps.
I will never be able to match my two 120 watt panels. As I said before, they are no longer made and besides, I don't have the room.
Mismatching panels of different size is a definite no go, so adding a third panel in parallel is a bad idea.
I am well aware of what series wiring does to 12 volt batteries. Why are we talking about it?
My original post was in regards to wiring a second controller. The rest is well known to me.
So running my two large identical panels that suffer no shading in series thru my MPPT controller will net more power to the batteries.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
