ReneeG
Sep 28, 2023Explorer
Lantley wrote:wa8yxm wrote:
With any water heater the water in the pipes heater to tap/shower is room temp.
And there is your quart. the Tankless has hot water coming out the outlet within half a cup.
Go home. Turn on the shower. How long before you get hot water out of your tank type water heater?
The only disadvantage to Tankless is you have a minimum flow rate before it heats.
There is definitely a delay with tankless. A tank heater has 130ยบ water ready to go. A tankless does not. The cooler water in the pipes is a factor for both. Tankless does not produce hot water instantaneously. It takes a few moments for tankless to produce hot water. You will notice the lag or delay with tankless in a house or RV.
That said tankless is a very bad idea for an RV.
My 10 gallon tank water heater gives me unlimited hot water. I never run out.
Having unlimited hot water via tankless is a fallacy.
You don't have unlimited supply nor do you have unlimited waste water storage.
Agree. We would never have a tankless, nor a 12v fridge as both seem to the norm with the newer RVs. As for the tankless, friends of ours reported filling a dish tub full of water before it even got hot, hence he installed a mod noted in my other post. We have a tankless in our house and even with the water at full blast, there is a delay up to a minute for the faucets furthest away from the tankless. In that delay, an easy two gallons can be collected.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
