Raynbowman
Jul 31, 2016Explorer
Walls are insulated back side is approximately 5" clearance, top is unobstructed and vented.
Reefer is out of camper for now. When using LPG and using eyebrow control at top of unit, there is no change in flame when adjusting from 5 to 1 or 2 or 3 or 4 Flame does not go out, flame does not change. Fridge compartment temperature is at 38f
wasatchmtnatvr, what I do not understand is, if all controls are out of picture (disconnected) and LPG is applied to system by bypassing controls (it went to 50f and 80F overnite), why then does the unit not just turn into a freezer completely? Does the unit not become like my 30 old, non technical reefer? Pull to over ride thermocoupler unit and activate striker to start burn until it has developed enough heat to develop enough currant to keep solenoid open.
Is the board in Dometic faulty?
Your analogy is spot on.
