Micro-Air
Mar 23, 2017Explorer
DieselBurps wrote:Glad to be here to help!
With my A/C turned on and when the compressor cycles or kicks off, the fan continues to run, so the fan timed delay seems like it would only matter on initial start up? Maybe the easy start compressor start sequence is enough to enable my A/C to cycle back on with the Honda generator in ECO mode?
If your particular A/C keeps the evaporator fan on after the compressor cycles off, and yours is a Coleman low-profile, then yours likely has two separate fan motors. All the Polar Cubs and Mach 8s do in fact have 2 separate motors. So, although the evaporator fan may keep on running, I believe the condenser fan motor will start up coincident with the compressor (normally). Then, since the EasyStart will only delay the compressor startup, the effect on the Honda's ECO mode behavior should be the same. That is, the condenser fan starting up should be enough extra load to kick the Honda up to high RPM before the compressor starting sequence orchestrated by the EasyStart begins 5 seconds later.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
