Jethroish
Oct 18, 2021Explorer
Thermoguy wrote:
I have a friend with a 2 year old RV with a Norcold fridge. He is expressing the same problems you are. He had it in the shop, they had it working fine. Took it on a trip, we were there with him, same problem. He has a thermostat and it never got below 53 degrees. Has to bring an ice chest with him to keep food cold. He has had it out only a few times, but always the same problem. Turning it all the way down, he can get it to start to get cold, but then never gets cold enough. His freezer works fine, just not the fridge.
His solution is to remove the fridge and put in a Dimetic. I think there is just a problem with this Norcold fridge and it's not repairable.
I have a 2021 Jayco with Norcold (NOTCold) 12v fridge. Worked great on the last trip in Sept. First of Oct, it was not getting cold. I have an appt with service dept, but when talking to them on the phone, the tech is pretty sure it needs replacing. Lights work and you can hear the fan running. Sitting level and plugged into 30amp.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
