azrving
Aug 15, 2018Explorer
My son FW looks just like that. One for landing gear one for slide. The big red wire at the top of the left breaker is the battery. It feeds the right breaker. You can check by removing one wire.
Safest way is to disconnect the battery then disconnect the bottom wire on the right breaker then reconnect the battery and try the slide.
Usually the two biggest draws are landing gear and slide and they run through breakers like that
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
