azrving
Aug 15, 2018Explorer
time2roll wrote:1L243 wrote:Breaker is there to protect the wire. Different load = different wire = different breaker.
What's the purpose of the second breaker?
Do yourself a favor and replace both with Bussmann Hi-Amp with same ratings.
Good point time 2 roll
I have seen that clicker type breaker go into melt down and take out wiring harnesses. When a fault happens the breaker heats a metal strip and the contact tips pop open. It cools and pops closed only to quickly heat up and pop open. Eventually the tips weld and wires go into melt down. Can't beat the manually resettable. They use them all over.... because they are cheap
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
