jseyfert3
Nov 19, 2019Explorer
wa8yxm wrote:
Not so much the OBD-II To Blue Tooth/Wi-Fi adapter (mine is BT) but the software on the display device.. I have used TORQUE (Free) and Torque (pro) It monitors every sensor I have (or so it appears) and gives me the ability to reset fault codes.. (not sure free does that).
NOW.. there are still some things that take a pro's unit to find. but so far the only time I've encountered anything like that. It also required special hardware to run the test not just the scanner.
Torque Free lets you reset codes.
Pro unlocks some extra features that free doesn't have. For example, I knew my Honda Pilot had a transmission temp sensor cause the dashboard has a transmission overtemp light. With Torque Pro I could enter the custom PID needed to "unlock" the sensor so I could monitor the temp.
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 12, 2025
