buddhawolf
Feb 22, 2020Explorer
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it still doesn't work, it may be a bad door switch or door switch mount.
One quick check is to gently hold down on the door while you press Start (or Cook).
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
