Bill_Diana
May 14, 2022Explorer
wa8yxm wrote:
Can not help you with the location but may be able to help you find it.
Follow the POSITIVE battery lead.. if you have issues due to bundled cables get a harbor freight cable tracker (about 20 to 30 bucks) and track it with Tweedle Dee And Tweedle Dum (You'll understand when you use it)
And when done... The POSITIVE cable.> RED paint or tape or split loom or if it's a cable where you can free a small end heat shrink tubing.
Black on the negative cable.
Thanks for the advice. I'm totally baffled as to where the terminal block is located.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
